1991 Chevy S-10 carrier bearing on split drive shaft
131,000 MILES • 6 CYL • 2WD • AUTOMATIC
TLZIMMERMAN
How does the bearing come off?
Jul 24, 2010 at 3:39 AM
HMAC300
  • 48,601 POSTS
you have to take the whole driveshaft out and pull the back section off then once the shaft is out with the support bearingthe center bearing is pressed on and you have to press it off.
Jul 27, 2010 at 7:24 AM
