1991 Chevy S-10 carrier bearing on split drive shaft
TLZIMMERMAN
MEMBER
1991 CHEVROLET S-10
6 CYL
2WD
AUTOMATIC
131,000 MILES
How does the bearing come off?
Saturday, July 24th, 2010 AT 10:39 AM
HMAC300
MECHANIC
You have to take the whole driveshaft out and pull the back section off then once the shaft is out with the support bearingthe center bearing is pressed on and you have to press it off.
