1991 Chevy S-10 Broken Vent
KRACK3
Air Conditioning problem
1991 Chevy S-10 Two Wheel Drive Automatic 150000 miles
My Chevy s-10 over heats alot and i think that is due to the dash vents not working. Air will blow on to the windshield and on the floor but the dash ones do not work. Also the truck will over heat almost immediately after turning the air conditioning on, or if u just turn the dial to cold. Is the fact air cannot pass easily through the vents causing my truck to overheat
Jun 2, 2010 at 6:15 AM
BLACKOP555
  • 10,386 POSTS
i would suspect that the cooling fans are not turning on or that the cooling fan shroud is cracked
Jun 3, 2010 at 4:58 AM
