1991 Chevy S-10
JAYHEG
Engine Mechanical problem
1991 Chevy S-10 6 cyl Two Wheel Drive Automatic
my truck started smoking when i drive or just push on the gas. it is white smoke coming from the tailpipe.
Feb 15, 2010 at 5:51 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Have you checked the coolant level?
Does it Over Heat?
The White Smoke/Steam is a good indication of a Blown Head Gasket.
Feb 15, 2010 at 6:03 AM
JAYHEG
yes i checked the coolant it is ok. noit does not overheat
Feb 15, 2010 at 6:14 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, need to pull plugs one at a time a take a good look at them. Compare them to the pics at the link below and post findings....
https://www.2carpros.com/how_to/how_to_change_my_spark_plugs.htm
I don't believe that vehicle has a vacuum line from the tranny to the engine.
Also, is it white smoke or bluish/white smoke?
Feb 16, 2010 at 12:47 PM
