1990 Chevy S-10 WHERE IS THE FUEL FILTER
EMWONCH
Engine Performance problem
1990 Chevy S-10 4 cyl Two Wheel Drive Manual
NEED TO KNOW WHERE THE FUEL FILTER IS AND HOW TO CHANGE IT.
Jan 6, 2009 at 10:47 AM
BUDDYCRAIGG
  • 2,262 POSTS
on every S-10 pick up or S-10 blazer i've worked on.
the fuel filter is in tucked inside the left frame rail.
just a little bit forward of the rear axle.
changing it is simple, you unscrew the fittings and then screw them back in.
Jan 6, 2009 at 3:36 PM
MRSOONERFAN
[quote:d0ecb334da="buddycraigg"]on every S-10 pick up or S-10 blazer i've worked on.
changing it is simple, you unscrew the fittings and then screw them back in.[/quote:d0ecb334da]
I just crawled out from underneath a 1990 S-10 blazer, 4 wheel drive. That is exactly where mine is located and every other one I have worked on. Happy wrenching....
Boomer
Jan 10, 2009 at 8:08 AM
