Test the booster with engine turned off and pumping the brake pedal until pedal goes hard. Then hold your foot on the brake pedal and start engine. If booster is working properly the pedal will go soft as it should for normal use. However, if booster is not working the pedal will stay hard.
Thanks for using 2CarPros. Com!
Saturday, February 28th, 2009 AT 9:24 PM
