All guages do not work, replaced fuses, tested all sending units and they all appear faulty. I could use a meter and resistor and the panel acknowledged each test as if the panel was receiving properly. Very Very remote all went bad at the same time. Speedo is the only working instrument. All lights in the background of the instrument panel appear to light up and work properly.
SPONSORED LINKS
Friday, August 15th, 2008 AT 11:31 PM
