1989 Chevy S-10 warning light on dash
BILL HANCOCK
Brakes problem
1989 Chevy S-10 6 cyl Four Wheel Drive Automatic
brake light light on dash is on replaced front pads and rotors as well as rear shoes and drums is it in either the equalizer sensor or maybe the emergency brake switch
Jan 27, 2010 at 6:33 AM
JDL
  • 16,098 POSTS
Welcome to the forum, thanks for the donation. Unplug the emergency brake switch, see if the lite goes out. Did you follow proper bleeding procedure? Is brake fluid level ok?
Jan 27, 2010 at 6:58 AM
