My truck started rather suddenly not being able to stay running. It actually went dead while I was running it to keep the battery charged. I changed
the plugs, wires and fuel filter. While I had the filter disconnected from line I turned the key on to see if the pump was working. Fuel diid pump out of line but I not sure if the pressures were right. If I put gas in the carburetor it will run only until the gas burns up. Are there any other filters or vacuum lines that could be giving me problems? Any tips?
Aug 24, 2009 at 5:05 AM
