1989 Chevy S-10 timing belt
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
RMURPHY4135
lowcation of timing belt and how to get to it.
Jan 25, 2010 at 1:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The 2.2L diesel engine is the only engine of this model and make which uses a timing belt instead of a gear or chain assembly. What size engine is yours?
Jan 25, 2010 at 6:10 PM
SCOTTY1128
ok the other guy is right it doesent use a belt your vehicle uses a timing chain which connects the cam and crank shafts togethr to open and close the valves a the proper time.
it is located in the front of the motor you must take out the radiator, then remove the front of the engine parts will run maybe $60 but its a 2-4 hour job
Jan 27, 2010 at 2:21 AM
