1989 Chevy S-10 oil leak
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
JRICHEY12345
Hey I have an 89 s10 that I'm putting a factory reman engine in and I had everything hooked up and while I was priming the oil pump and lifters with a drill and distributor with the cam gear cut off I noticed a significant leak on the oil pan gasket in the front below the timing cover. I bought a new oil pan for this engine and new gasket of course. I used rtv on the gasket between the pan and the gasket but not between pan and engine. I also was trying to use sythetic oil and I was wondering if I should just use conventional and it might stop. Also I was wondering if starting and warming the engine up would make the gasket seal better and maybe stop the leak. Any advice?
Sep 6, 2010 at 2:43 PM
DOCFIXIT
  • 18,828 POSTS
Hi
RTV is problem does not adhere well to gasket. Scrap off install new gasket.
Hope this helps
Thanks for donate
Sep 7, 2010 at 7:50 AM
JRICHEY12345
So just put the gasket on with no rtv or any sealant)??
Sep 7, 2010 at 11:03 AM
DOCFIXIT
  • 18,828 POSTS
Yes it makes a hydroscopic seal to hold in place parts house has clips to hold. You can go all RTV RED no gasket
Sep 8, 2010 at 2:46 AM
