1989 Chevy S-10 no power to fuel pump
CHESTER1028
Electrical problem
1989 Chevy S-10 6 cyl Four Wheel Drive Automatic
I removed the dashbaord and replaced it and now it won't crank and I don't know if there is a reset button or something. Is there something I should be looking for?
Thank you in advanced
Sep 26, 2009 at 12:19 PM
  • 75,988 POSTS
If it wasn't doing that before you went behind the dash best check the wiring harness that goes to the ignition switch and for loose connections somewhere in there-
Sep 26, 2009 at 2:32 PM
