1989 Chevy S-10 No fire from distibutor
205,196 MILES • 4 CYL • 2WD • MANUAL
HANDCOCK41
  • 7 POSTS
Ive replace the distributor cap, rotor, pickup coil,helli effect switch,engine coil,module and still no fire. Took number one spark plug out no fire. Turned the crank shaft to see if distributor rotor was turning and it is. Please help. I NEED MY GAS SAVER!!! :-(
Feb 24, 2010 at 3:14 AM
JDL
  • 16,098 POSTS
hi, thanks for the donation. Did check primary voltage at the coil, pink wire, use a testlite, goes hot when you turn on the key.
Feb 24, 2010 at 7:06 AM
HANDCOCK41
  • 7 POSTS
My dad and i tested all the wires that had to do with fire going to the distributor. the testor lit up on all wires. no fire coming from the distributor. dont know if this will help but i was doing 60mph on interstate when it just shut down. truck was running darn good before this happen. no warning the problem was coming.
Feb 25, 2010 at 2:53 AM
JDL
  • 16,098 POSTS
Hi, I need definitive answer on the pink wire, that is primary voltage to the coil, goes hot with the key on. If there is voltage use testlite on tach/negative side of coil, engine cranking, there should be a pulse. With any electrical part, if the wiring circuit is faulty, replacing the part won't fix it.
Feb 25, 2010 at 4:51 AM
HANDCOCK41
  • 7 POSTS
Thank you for getting back with me. i will test that wire once again. will get back with answer tomorrow. again thanks a lot for your help!!
Feb 26, 2010 at 2:54 AM
HANDCOCK41
  • 7 POSTS
i did like you said and tested primary voltage to the coil. i am getting fire from there. i tested the negative side and there is no pulse when engine is cranking. what should i do next?
Feb 27, 2010 at 3:13 AM
JDL
  • 16,098 POSTS
Are you saying, voltage on the negative side but, no pulse? Engine cranking, do you have injector pulse? Does the rotor turn when you crank the engine?
Feb 27, 2010 at 4:14 AM
HANDCOCK41
  • 7 POSTS
just learn my problem. distributor was not turning once i pull cap off to observe. pull timing gear case off and notice that the timing gear was missing some teeth. im being told different things to do. should i pull the head or just replace the gear?
Mar 1, 2010 at 12:28 AM
JDL
  • 16,098 POSTS
You should be able to get a timing gear set. gears and chain.
Mar 1, 2010 at 1:12 AM
HANDCOCK41
  • 7 POSTS
thank you for the advice. i think i can handle it from here. :-)
Mar 1, 2010 at 2:27 AM
2 LINSEY
  • 287 POSTS
Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
Mar 5, 2010 at 8:54 AM
