1989 Chevy S-10 need a hand
135,000 MILES • 4 CYL • 2WD • MANUAL
CHARLES_LIVENGOOD
alrite the s10 i have has new fuel pump, fuel lines, fuel filters, injector plugs wires and the pickup coil in the distributor... now the question i have is why would it not wanna stay runnin...it runs high rpm's the stalls out...thought it was a vacuum leak but there isnt one...so it seems more like it jumped time but i was told that they dont have a timing chain on them that they were gear to gear. so i think the problem lies in the distributor but im not sure so if u could help me out it be much appreciated...note convertor isnt clogged either...
Sep 20, 2009 at 2:27 PM
  • 75,988 POSTS
Clean out the idle air control valve, test the TPS and MAp sensors and do a fuel pressure test
Sep 20, 2009 at 8:29 PM
