1989 Chevy S-10 V4 Two Wheel Drive Manual 142000 miles
I was driving home tonight and was running about 60-65 against the wind and I noticed that my began to run pretty rough. It was making a weird noise and sending alot of vibration through the whole truck. I just happened to be going past a guy who I knew had some experience with a S-10's and I stopped and asked him to help me out. We looked at it and we figured out that its not hitting on the front two cylinders. We popped off the front two wires and it didnt even phase the truck. However the back two wires if pulled off would make the truck run even worse. So we pulled the plugs and noticed they were pretty wide on the gap and pretty dirty. I changed all the plugs, wires, cap and roter in June. So we gapped them right and cleaned them off. We also made sure that the spark was going all the way through to the plug which it was. We put them back in and it still ran rough. So we went to town and bought a new set and did the same thing with the same result. Its still running really rough and on only two cylinders. My buddy said it might be the timing? Idk. Im hoping you might have an idea.
SPONSORED LINKS
Sunday, December 2nd, 2007 AT 9:59 PM
