89 Chevy S-10 2.5L. I have been having idle problems and can't figure out the problem. I replaced EGR valve but wasn't sure what washer # to put in. I put in #26 please advise. In addition, changed plugs, thermostat, checked all vaccum lines and replaced as necessary. New PCV valve. O2 sensor and fuel filter. When I start it, it starts cold no matter the weather. Idles very high and sometimes runs normal after 5 min, and sometimes idles so low it won't stay running without throttle. The Service engine soon line is intermittent. Please help if you can.
Thanks
Thanks
Mar 18, 2008 at 2:44 AM
