Back in the 80's most pumps came as one piece, pump, strianer, and sender. Remove the battery negative cable before you start, do the job when there is about 1 gallon left in the tank, If you don't have the spanner wrench, use a hammer and brass punch to remove the lock ring!
SPONSORED LINKS
Saturday, December 22nd, 2007 AT 7:32 AM
