1989 Chevy S-10 Exhaust maniflold
400,000 MILES • 4 CYL • 2WD • MANUAL
MRDIETRICK
I recently replaced a cracked exhaust manifold but the noise is even worse. The gasket looked fine so I did not replace it. Is there something else I should check?
Nov 12, 2008 at 1:31 AM
SWILLIAMS
  • 597 POSTS
Gaskets are a one use item. Once they are torqued you need to replace them if you remove the part again.
Nov 12, 2008 at 3:07 PM
