1989 Chevy S-10 Engine Overheating
78,000 MILES • 4 CYL • 2WD • MANUAL
CHRIS1
The two center ports on the exhaust manifold get glowing red hot but the front and the rear are normal. The vehicle was running fine. The timing gear broke so I replaced timing gear set and this problem started. Other than that the vehicle runs fine. It starts and runs normally. Can anyone help?
Nov 29, 2009 at 3:30 AM
  • 75,988 POSTS
