The two center ports on the exhaust manifold get glowing red hot but the front and the rear are normal. The vehicle was running fine. The timing gear broke so I replaced timing gear set and this problem started. Other than that the vehicle runs fine. It starts and runs normally. Can anyone help?
Nov 29, 2009 at 3:30 AM
