1989 Chevy S-10 egr valve
186,000 MILES • 4 CYL • 2WD • AUTOMATIC
NICO89
My truck will start but stalls at a stop or even when trying to reverse. Then it takes a while to start back up.Took it to a mechanic that said the egr valve needed to be replaced. He also said i should just replace the engine. Also something about the oil pressure not being high enough to allow the engine to push enough gas to where it needs to go. Something like that. Could the engine be salvageable? Could it be the egr valve needs to be replaced?
May 21, 2009 at 11:57 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:29c9bf5922="Nico89"]Engine Performance problem
1989 Chevy S-10 4 cyl Two Wheel Drive Automatic 186000 miles
My truck will start but stalls at a stop or even when trying to reverse. Then it takes a while to start back up.Took it to a mechanic that said the egr valve needed to be replaced. He also said i should just replace the engine. Also something about the oil pressure not being high enough to allow the engine to push enough gas to where it needs to go. Something like that. Could the engine be salvageable? Could it be the egr valve needs to be replaced?[/quote:29c9bf5922]
Check out this link about Why does my car engine stall?
https://www.2carpros.com/first_things/engine_stalls.htm
May 21, 2009 at 12:31 PM
