I have done extensive testing on my truck, but i am not a mechanic, just someone determined to fix it myself. Truck runs, but bucks terrible...loves 15mph, smooth as glass. Before it went down totally, on freeway, truck would hesitate at high speed (70mph). Now it is throwing a code 22 (tps) and 34(map). The ESC has juice from B terminal. I did several tests for the map and tps, egr solenoid, replaced egr, injectors are firing and at wot, they do their thing (conical spray). Replaced fuel filter, had fuel pressure checked (12psi) which is within spec, relays work, throttle works, but if you step on the gas, it bucks and dies. I pulled the ECM, it is getting just under 12v on both orange wires...map and tps at the ecm has the correct voltage with key on engine off. I am thinking i need a new ecm.....the one on the truck is the original. BTW, the engine was replaced 2008, and tranmission shortly thereafter. Spark plugs are all firing and are clean. I am tired of trying to find this problem. Any suggestions would be awesome. thank you, mary
Nov 5, 2010 at 1:05 PM
