1988 Chevy S-10 timing chain
FREEON3RET
Engine Mechanical problem
1988 Chevy S-10 6 cyl Two Wheel Drive Automatic
i recently aquired a 1988 chevy s10 durango 2.8 v6 tbi it hasent ran in 2 yrs i put a fuel pump on got it running drove it around the block 5 times let it sit for a month went out to fire it up it ran for about 5 mins and BAM it shut down oil every where the timing chain broke busting the front cover and the tensioner too . what would cause this to occur ?
PLEASE HELP THANK YOU .
Sep 1, 2010 at 12:37 AM
  • 31,937 POSTS
Hi there,
With out being able to investigate the failure first hand i can only offer my summation on what may off happened, there could have been a number of reasons, but i feel the most likely are a failure of the tensioner, a chain failure due to stretch, this could also account for a tensioner failure as if the chain was well over length due to wear the tensioner may not have been able to take up all the slack, a failure of a chain runner allowing to much slop in the chain, a failed tooth on a drive gear, maybe a closer investigation of the failed components will shed some light on this for you.
mark (mhpautos)
Sep 1, 2010 at 12:47 AM
