1988 Chevy S-10 explain in detail please computer ground
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
MICHAEL33005
  • 10 POSTS
where are they intergrated on computerplease explain in detail
Dec 26, 2008 at 9:21 AM
BMRFIXIT
  • 19,053 POSTS
I just noticed that !!!????
you need to stay in one post and do not write new post every time
just hit replay to question
only way we can keep up with what is you are trying to do
the( ECM /PCM /Computer )job is to ground the injector and its a circuit board
and not a serviceable unit
check the TPS volts
Dec 26, 2008 at 10:02 AM
MICHAEL33005
  • 10 POSTS
Does TPS stand for throttl position sensor?
Dec 26, 2008 at 12:19 PM
BMRFIXIT
  • 19,053 POSTS
Yes TPS is the throttle position sensor
see if its volts high then the computer will shut down the injector
this is what was called a flood mode
Dec 26, 2008 at 3:08 PM
MICHAEL33005
  • 10 POSTS
What should the TPS read? If it is to high what should I do?
Dec 27, 2008 at 3:33 AM
JMICHAEL8888
  • 45 POSTS
im sure you know this , but just in case there are two blk/white system ground wires coming out of the computer at pinouts A12 and D1. this is the only grounds you can check.
Dec 27, 2008 at 10:06 AM
BMRFIXIT
  • 19,053 POSTS
TPS volts should be under 1 volts
and as u step on the gas the volts should start to increase
if it volts high at idle disconnect the TPS and try it, crank ,check if u get injector pulse
and if u have it then I would say replace the TPS
good luck
Dec 27, 2008 at 11:51 AM
MICHAEL33005
  • 10 POSTS
when the fuel injectors pulse but right now that are not still trying to figure it out. When the ignition is on do they have voltage? If so what is it? When they do pulsate are they supose to be less than a volt?
Dec 28, 2008 at 7:19 AM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_8_21_2007_13_3_11_2.jpg
When key on you should have a battery volts at one of the injector wires and when cranking the computer should pulse ground the other wire causing the injector to pulse on of f remove the injector plug wire and stick a noid light in crank the engine does it flash if all ok it should and then check your fuel pump and fuel pressure
Dec 28, 2008 at 1:08 PM
MICHAEL33005
  • 10 POSTS
dose the timing have to be dead on,or can it be off alittle bit and still start.
Dec 31, 2008 at 10:06 AM
BMRFIXIT
  • 19,053 POSTS
the timing has to be on
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_142.jpg
Dec 31, 2008 at 11:02 AM
MICHAEL33005
  • 10 POSTS
the destribiter,dose it have to be dead on at tdc.
Jan 1, 2009 at 12:29 AM
BMRFIXIT
  • 19,053 POSTS
As a helper cranking the engine u can turn the distributor left and right a bit
see if that help
if the distributor of a bit it should try to start but if a lot no
Jan 1, 2009 at 3:01 AM
MICHAEL33005
  • 10 POSTS
what should i do if that don't start the truck
should i take the destribiter out and try retiming it
Jan 1, 2009 at 3:10 AM
BMRFIXIT
  • 19,053 POSTS
I wouldn’t take the distributor out just for trying
rotating the distributor left and right should compensate for any timing of if any
if not then you are looking in the wrong area
and or timing chain is out of timing
Jan 1, 2009 at 10:29 PM
MICHAEL33005
  • 10 POSTS
how do you change it from 2wheel to four wheel high & low
do you put it in park or put it nutral
do you back up in between changing from 2 & 4H&4L
Jan 4, 2009 at 2:03 AM
BMRFIXIT
  • 19,053 POSTS
Neutral
brakes on
shift to 4 low
Jan 4, 2009 at 2:31 AM
MICHAEL33005
  • 10 POSTS
no. one at tdc ,what is the location of the destribitor, show picture
May 3, 2009 at 3:22 PM
