Electrical problem
1987 Chevy S-10 6 cyl Two Wheel Drive Manual
I have a guy trying to get my truck cranked after the engine swap. He says that the fuse for the fuel pump & fuel injectors blow everytime he goes to crank it. He cannot find out what is causing the fuse to blow. The truck will run for a second or so and then the fuse will blow. Your help would be much appreciated. Thanks, T.
Jan 10, 2009 at 3:24 AM
