1987 Chevy S-10 How to set timing
128,000 MILES • 6 CYL • 2WD • AUTOMATIC
COURIER81
  • 12 POSTS
I am confused on how to install the timing chain with the marks pointing correctly. I had already removed the heads in order to have a valve job, and checked the timing chain and noticed it had jumped timing. Chain was real loose.
Anyway, I installed the chain with the marks facing each other, and the No. 1 cylinder at TDC. Did I do this right?
Jun 29, 2010 at 1:09 PM
2CARPRO JACK
  • 11,533 POSTS
Yes, the two marks should be facing each other, you got it right
Jun 29, 2010 at 3:04 PM
