1986 Chevy S-10 s-10 wont start
105,000 MILES • 4 CYL • 2WD • MANUAL
DREWSKI86
i have a 4cyl 4 speed 86 s-10. it will not start . has new battery , fuel pump, and new oil/ oil filter.. when i hooked up the battery, i got it to turn over. but after a few times it completely stopped and nothting is responding.. the battery was checked and is still good. i bought it from a friend, he had it after his dad past, it sat for 3 years, he changed the fuel pump. after that it would start but not run. what could keep it from cranking and is it fixable
Dec 27, 2009 at 8:50 AM
  • 75,988 POSTS
Did you meant it cranks over and will not start or just won't crank at all/nothing/nada?
Cranks and w/n start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
No crank at all/nothing/nada:
Could be the starter, starter relay, park and neutral switch and ignition switch assuming the battery and connections are good.
Dec 27, 2009 at 9:29 AM
