I have two problems. The first is the temp gauge always reads at the lowest, heater and defroster both put out heat, both lower and upper radiator hoses are hot but the overflow hose is not hot. Is it the thermostat? Second problem, the engine idles too high and I do not see anywhere it can be adjusted. Thanks
Apr 30, 2009 at 5:44 AM
