1986 Chevy S-10 no start
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
LOMAX51
spins and fires fuel pressure is good. will start if you pour gas in throttle body , but the injector driver is not working, also rerplaced computer and chips x2. checked wires to computer can grnd driver side of injector and will spray. HELP and thanks. lomax51.
Oct 29, 2009 at 1:19 PM
BMRFIXIT
  • 19,053 POSTS
Lets try and clarify few things
engine crank
but will not start,
have spark ,have fuel pressure
and fuel flow
PCM was replaced ,still no start
did you check for injector pulse
check PCM data
what is it you have for TPS volts
Oct 29, 2009 at 2:14 PM
