1986 Chevy S-10 injector
160,000 MILES • 4 CYL • 2WD • MANUAL
SEARLS01
i have good pressure coming from fuel pump and the injector will not squirt fuel the voltage is also fine i shoot either in the throttle body and it will run all fuses are good as well and the computer has no burn marks in it
Mar 21, 2009 at 10:06 PM
JDL
  • 16,098 POSTS
What is the fuel pressure, you can't check it without a gage.
If the injector isn't pulsing, I wonder about the rpm signal? The purple wire with white tracer at the dist. should have a pulse, with the engine cranking. Any codes?
Mar 22, 2009 at 2:19 AM
