1986 Chevy S-10 hydrauliic clutch bleeding
107,500 MILES • 6 CYL • 2WD • MANUAL
LONEWOLF2634
I was just wondering if there is any special procedure to bleeding a clutch. Ihave tried a couple times and the clutch does not seem to be getting any better if anything it is higherin the relaease.
Oct 13, 2010 at 10:54 PM
BMRFIXIT
  • 19,053 POSTS
BLEEDING HYDRAULIC CLUTCH SYSTEM
Fill reservoir with clean DOT 3 brake fluid. Raise vehicle. Disconnect slave cylinder from bellhousing, leaving line attached. Hold slave cylinder at angle of 45° with bleeder screw at highest point.
Have an assistant depress clutch pedal while you open bleeder. Close bleeder and release pedal. Repeat sequence until all air is removed from system. Make sure master cylinder reservoir stays full during bleeding process.
Oct 13, 2010 at 11:10 PM
