Hello, I'd check for spark at the plugs, with the engine cranking. If there is no spark and the coil is in the cap, use a testlite on the tach terminal, should be a pulse with the engine cranking. You could also check for b+ at the coil.
SPONSORED LINKS
Wednesday, March 4th, 2009 AT 2:21 PM
