1986 Chevy S-10 Fuel problem
136,000 MILES • 4 CYL • 2WD • MANUAL
EVANSHAUL
My chevy s-10 wont start.The injector doesnt seem to work,ive tested the wire going to it and it has constant 12 volts when the key is turned on!Ive had to put gas down the throttle body for months to get it started when its cold,and its always started,until yesterday and know nothing!The fuel pump runs until the relay shuts it off,the injector is new and so is the fuel filter.I dont know what else it could be,can anyone help me please?
Mar 29, 2010 at 3:18 PM
  • 75,988 POSTS
Power the fuel pump from the battery if it fires up check and test the fuel pump/oil pressure sending unit. If okay could be the computer injector ground driver/s
Mar 29, 2010 at 6:58 PM
