My S-10 runs great when it is first started, but after you drive it down the road for about a mile or so when the engine gets warmed up, it has a miss on two cylinders, I believe on the passenger side. I have replaced the fuel pump, gas tank, plugs, plug wires, distributor cap, rotary button, igiition module, ignition coil, air filter, and fuel pump. What else can be causing this??
Mar 4, 2008 at 9:55 AM
