1986 Chevy S-10 Blazer Burning ECM - short?
230,000 MILES • 6 CYL • 4WD • AUTOMATIC
REALAMERICAN
I own a 1986 Chevy S-10 Blazer. I keep burning up a component inside my ECM. My truck runs fine until the ECM burns up, usually after a day after installation. Then the truck misses throughout the speed range, and backfires occasionally. After the ECM burns up, I check my timing and the timing is way off. Resetting the timing fixes the backfire problem but it continues to miss random cylinders. I have new spark plugs and wires and a relatively new distributer. I have uploaded a picture to show which chip is burning up, in hopes that somebody has the schematics to determine what this chip controls. Something has got to be shorting out somewhere. [img:8c4ab2f695]http://www.2carpros.com/forum/automotive_pictures/136989_DSC00508_copy_small_1.jpg[/img:8c4ab2f695]
If you need a larger, more detailed picture, I have them available to email. If you need any other info, I'll give it to you. Im at the end of my rope here. Any ideas?
Jan 1, 2008 at 3:26 AM
FISHERMAN
  • 937 POSTS
Hello !! Well It`s going to be hard to find an schematic for the ECM but i have a suggestion: follow the circuit board lines that leads to the chip and see the color codes on the connector, that way I can get you an a wiring schematic and with the color of the wires we will know what sensor/actuator or device its feeding... what do you think? let me know!! Good luck! BTW Thanks a Lot for your donation! I`ll be in contact!
Jan 2, 2008 at 2:48 PM
REALAMERICAN
Ok, I looked at the bottom of the board. Most of the leads go to other chips, all of which look fine. There are four leads that run to the electrical connectors. I have uploaded pictures of my trace and have labeled everything.
https://images.2carpros.com/forum/automotive_pictures/136989_DSC00511_copy_1.jpg
https://images.2carpros.com/forum/automotive_pictures/136989_DSC00515_copy_1.jpg
https://images.2carpros.com/forum/automotive_pictures/136989_DSC00516_copy_1.jpg
Wire 1 leads to Connection A2 which runs into a brown wire Wire 2 leads to Connection A3 which runs into an empty socket Wire 3 leads to Connection C1 which runs into a black wire with a purple stripe Wire 4 leads to Connection C2 which runs into an empty socket.\
Jan 3, 2008 at 3:08 PM
FISHERMAN
  • 937 POSTS
Hello !! Waoo!! you`re good on pictures !! Well I have the schematic on my computer if I post it its going to loose its quality I`m Going to sed it to your mail and we can continue with the troubleshooting in here. I`ll be around here... (raining outside.. bad fishing day lol )
Jan 4, 2008 at 10:03 AM
FISHERMAN
  • 937 POSTS
Hello !!
Well I was checking the diagram and by the connexion number (the color is different) the A1 Dark green-white (the brown on yours) feeds the fuel pump relay...
And the C1 black-Pink feeds the air control solenoid...
What do you think?
let me know if you find the same codes..
Jan 4, 2008 at 10:40 AM
REALAMERICAN
Lets see, Mines A2, not A1. A2 is connected to the air conditioner relay. i dont know if it could burn out the ECM but I did have A/C problems. There was no current to the A/c relay before. I will have to check the wires on this to check for a cross. As for C1, where is the air control solenoid located? C2 says it goes to the 'air sw sol' what solenoid is this? and why doesnt my ECM plug have a wire for it?
Jan 4, 2008 at 2:21 PM
FISHERMAN
  • 937 POSTS
[quote:d05afd4298="RealAmerican"]Lets see, Mines A2, not A1. A2 is connected to the air conditioner relay. i dont know if it could burn out the ECM but I did have A/C problems. There was no current to the A/c relay before. I will have to check the wires on this to check for a cross. As for C1, where is the air control solenoid located? C2 says it goes to the 'air sw sol' what solenoid is this? and why doesnt my ECM plug have a wire for it?[/quote:d05afd4298]
Hello ..
I write down "air control Solenoid" on the search engine of the Mitchell1 and shows "0" which means wont apply for your specific model the only option is a cross wire on the path of the A2 (A/C relay)...
question: is there other burn impress circuit that leads to the burnt chip? or just those two?
Jan 4, 2008 at 2:32 PM
REALAMERICAN
its just two. If the air control solenoid does not apply to mine, what does the wire go to?
Jan 5, 2008 at 6:17 AM
FISHERMAN
  • 937 POSTS
[quote:ce188e4277="RealAmerican"]its just two. If the air control solenoid does not apply to mine, what does the wire go to?[/quote:ce188e4277]
Hard to tell......
Anyhow check that wire and see if its grounded or shows voltage .......
same to the A2.......
Jan 5, 2008 at 9:35 AM
MASTERTECHTIM
  • 4,750 POSTS
i have a few suggestions. first if the timing keeps changing without the distributor moving your problem is the mainshaft in the distributor. check for cracks around the reluctor wheel, that has to be why timing is changing. on the burning of the ecm check the resistance of every single solenoid, egr solenoid, diverter solenoids tcc solenoid etc. they must have a minimum of 20 ohms resistance or it acts like a dead short to ground.
Jan 5, 2008 at 10:50 AM
FRANK TEIXIDO
  • 9 POSTS
pictured two there is a piece of RV2 red color.
What is Component?
Dec 6, 2014 at 3:31 AM
FRANK TEIXIDO
  • 9 POSTS
Varistor ?
Dec 8, 2014 at 7:09 PM
FRANK TEIXIDO
  • 9 POSTS
varistor 50V ? = RV2
Dec 11, 2014 at 1:53 AM
