1986 Chevy S-10 86 chevy gets fuel and spark but wont start
105,000 MILES • 4 CYL • 2WD • MANUAL
DREWSKI86
i have an 86 s-10, i bought from a friend.. he put in a new fuel pump and after that it sat for 3 years.. i came up on it. changed the battery and plugs , flushed out and re did the oil, and we found the pump wasnt hooked up right.. i fixed it, it gets fuel (with good pressure) and spark now, it does turn over but still it wont start.. could it just be the old gas? or maybe plug wires arent giving enough spark? or timing? the injectors are good and its getting fuel to the chambers..
Dec 29, 2009 at 2:41 PM
  • 75,988 POSTS
You are getting a snapping blue spark, the correct fuel pressure and injectors are pulsing I suggest you check the valve and ignition timing-Double check the fuel system
Dec 29, 2009 at 6:54 PM
GIRLMECHANIC
I have an 1986 S10 too and I had problems getting it to crank, it was getting both fuel and spark. I had to pump it over and over while trying to crank it to get it to start. I am having problems still with mine with high idle. I wish you lots of luck with your 86. still don't know why I had to do that to get it to start. It only did that on first start of the day.
Dec 30, 2009 at 4:14 AM
  • 75,988 POSTS
TO: girlmechanic,
Check your fuel pressure if okay test the coolant temperature sensor and fuel pump/oil pressure sending unit
Dec 30, 2009 at 7:28 AM
