1985 Chevy S-10 starting
JEROMENILES
1985 Chevy S-10 V6 Four Wheel Drive Manual 100000 miles
Hello, I have a 85 s10 4x4. Yesterday I went to start it and it would barely crank. I tried to jump it but I had no luck, it would still crank slowly. Today I changed the battery, replaced the battery ground, replaced the ground strap (from the firewall to a valve cover bolt), and replaced the starter solenoid. I have power to the lights, radio and all accesories but now it will not crank at all. please help!!!
Jerome.
Dec 8, 2007 at 10:34 AM
  • 75,988 POSTS
Hold the key in start position while looking for power at the purple wire at the solenoid-do you have it if so the starter is defective and also see below circuitry.
https://images.2carpros.com/forum/automotive_pictures/12900_starting_circuit_1.jpg
Dec 8, 2007 at 10:16 PM
