Electrical problem
1985 Chevy S-10 6 cyl Two Wheel Drive Automatic
I have found a post buy another member that has the same issues, my 1985 S-10 pick-up does not get spark from time to time. I replaced the cap,rotor, coil and the "pick up" under the rotor. after everything i have done it still doesn't fire every time. i can go months with no problem then i can't get it started 4-6 times a day, then it will be fine for up to a month. i even went as far as replacing the "brain" (as little as it is). can anyone help?
Jun 7, 2008 at 9:32 AM
