1985 Chevy S-10 EFE
PATGROVE1954
Engine Performance problem
1985 Chevy S-10 6 cyl Four Wheel Drive Manual 1K miles
New engine and carb. We omited the EFE gasket below the carb. We have some hesitation on exceleration. I was told the screen in the EFE atomises the fuel and without it I was dumping to much fuel at once. If I slowly press the acceleraton the vehicle does not hesitate. Thanks
Sep 20, 2010 at 5:15 PM
HMAC300
  • 48,601 POSTS
best thing to do here is put it back on and see if it quits. If it does, then your problem is solved. If not it's something else. check for vacuum leaks/ timing stuff like that first...
Sep 21, 2010 at 11:59 AM
