1985 Chevy S-10 car only starts when stater fluid is spraye
10,000 MILES • 6 CYL • 2WD • AUTOMATIC
DONNA48
Truck will only start when starter fluid is sprayed into it///and now the hood release inside the truck has broken and i cant get the hood opened /i have just lost my job and am single & cant afford a mechanic or tow truck to get it to someplace to check it out //thanks
Jan 13, 2008 at 6:06 AM
STEVE931
  • 12 POSTS
Looks as if your engine has lost compression.If you take the oil filler cap off w/engine running and it is blowing air and some smoke out of it this is probably a problem in your bottem end,Rings,cylinder wear.piston's,etc. If not blowing out oil filler you probably have valve trouble in top end,heads,. Either way this will not be cheap.Sorry. Steve931 :roll:
Jan 14, 2008 at 4:37 AM
