1985 Chevy S-10
117,000 MILES • 6 CYL • 4WD • MANUAL
MWENDT14
my transmission makes this really bad whinding noise and i cant figure it out, also my engine just dont seem to have very much power do you think its my carburetor maybe you guys can help me please.
Nov 16, 2008 at 5:27 AM
DIRTYDIME03
  • 14 POSTS
With it being manual start the truck and when it starts to whine push in the clutch if it goes away it's your throw out bearing for the clutch. When you say your truck is a v6 that leaves 2 options, the 2.8 or the 4.3. Honestly the 2.8 makes enough power to barely get out of its own way, on the other hand the 4.3 is a very strong motor. If you think it's your carb run some carb cleaner through the fuel system. I HIGHLY reccomend seafoam for an over the counter carb cleaner. It's not cheap at all but it does a GREAT job and it does exactly what it says it'll do.
Nov 17, 2008 at 11:15 AM
KILLCHAIN187
[quote:a6f026583a="mwendt14"]Transmission problem
1985 Chevy S-10 6 cyl Four Wheel Drive Manual 117000 miles
my transmission makes this really bad whinding noise and i cant figure it out, also my engine just dont seem to have very much power do you think its my carburetor maybe you guys can help me please.[/quote:a6f026583a]
Combination of your clutch and throwout bearing. Does it seem to shimmy a little when you have it in gear with the clutch depressed? Mine did that; took it to a transmission shop and they fixed it right up. Cost $800 but whatever.
Jan 31, 2009 at 5:30 AM
