1984 Chevy S-10 volt gauge reads 16-17 volts
1984 CHEVROLET S-10
60,000 MILES • 6 CYL • 4WD • AUTOMATIC
TOOOEY29
I had my ignition switch and linkage replaced a month ago and since then my volt gauge has been reading high(16-17 volts) I think it used to read around 13 volts before the switch was replaced. The battery is also new and alternator is supposedly in fine shape.
Jan 24, 2008 at 9:59 AM
Better check the voltage regulator its not controlling the alternator current output and the wiring that goes back to the ignition switch.
Jan 24, 2008 at 10:11 AM
