1983 Chevy S-10 engine runs ruff
SMOKY1970
Engine Mechanical problem
1983 Chevy S-10 V8 Two Wheel Drive Automatic
I have an early 80s 350sbc,Its fully rebuilt w/ A thumper cam.When its running it wants to pop back thru the exhaust ,wont idle just runs ruff.Can someone please help?
Mar 20, 2009 at 12:59 PM
  • 75,988 POSTS
Try cleaning out the idle air control valve and check fuel pressure -A large vacuum leak can lean the air/fuel mixture out to such an extent that an engine will not idle at all. An EGR valve that is stuck open at idle can have the same effect as a vacuum leak. So too can a loose positive crankcase ventilation (PCV) hose, a leaky PCV valve or the wrong PCV valve (one that flows too much air for the application). If somebody replaced the PCV valve recently, they may have installed the wrong PCV valve. The rough idle in all of these cases is caused by "lean misfire." The fuel mixture is too lean to ignite reliably so it often misfires and fails to ignite at all. Lean misfire will show up as elevated hydrocarbon (HC) readings in the exhaust, which may be enough to cause a vehicle to fail an emissions test.
Mar 20, 2009 at 10:04 PM
