I just replaced the intake manifold and carb. At first startup the truck fired up quick and sounded great. Now it appears to idle a little rough like it is missing. I have also replaced spark plugs, plug wires, rotor (distributor), and coil. When I rev it up it sounds smooth but I'm not sure I could tell if it was missing at that rpm. Is it possible that I put the distributor in and off by one tooth?
Sep 17, 2009 at 9:30 AM
