2002 Chevy Prizm Stuck crankshaft
2002 CHEVROLET PRIZM
120,000 MILES • 4 CYL • FWD • AUTOMATIC
BOB FELTY
I'm doing a rebuild, only have the crank left to remove, I've taken out all of the bolts from the main caps , but can't get the lower section or crank to move on one side.
Is their some thing special I need to do.
Oct 15, 2010 at 6:36 AM
BLACKOP555
  • 10,386 POSTS
is there a chain for the oil pump on there?
Oct 17, 2010 at 3:37 AM
BOB FELTY
no the chain has been removed, I found a bolt hid under the oil filter adapter, so the problem is solved.
the 20th bolt that holds the lower block to the middle section is hid under the oil filter adapter, I had to re-read my repair manual to see it. thanks anyway.
Oct 18, 2010 at 1:41 AM
BLACKOP555
  • 10,386 POSTS
glad to hear you have found the problem
Oct 20, 2010 at 2:41 PM
