2001 Chevy Prizm Ignition switch
106,540 MILES • 4 CYL • 2WD • AUTOMATIC
OZ44
Recently, the ignition switch will hang up and I cannot turn the car on. This happens with all of the 4 keys that I have, so I don't think it's a key issue. Turning the steering wheel slightly, one way or the other doesn't seem to help. Any ideas as to what is hanging up the ignition switch?? When the switch does release, it acts smoothly and the car starts right up. Sometimes, removing and re-inserting the key will cause the switch to release.
Nov 22, 2009 at 6:41 AM
BMRFIXIT
  • 19,053 POSTS
its the cylinder lock that need to be replaced
if you like to keep the same keys should ask a locksmith to repair it for you as they will take it and rebuit it best way out
Nov 23, 2009 at 12:17 PM
