2001 Chevy Prizm Engine won't start
CTALLADY
Engine Mechanical problem
2001 Chevy Prizm 4 cyl Four Wheel Drive Automatic
My car starts fine but after I drive it to my destination (to a store) and then I get back into my car it won't start again. I have to wait at least 45 minutes to an hour to restart it... Is this a fuel problem??
Jul 12, 2010 at 12:57 AM
  • 75,988 POSTS
Next time it refuses to start-don't wait for nothing-what you need to do is determine if its a fuel or spark problem that's preventing it from starting-Do below:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Jul 12, 2010 at 4:10 AM
SOSOSTLOUIS
  • 5 POSTS
Ok guys, the mechanic installed a remanufactured ECM on the 2001 Chevy Prizm but it still isn't starting. The spark plugs, coils, and fuel injectors are fine and working. The first mechanic (NTB) told me that the Prizm doesn't have a fuel pressure regulator but O'Reilly's told me that it does have one. Can you show me a diagram of exactly where the fuel pressure regulator is location in the 2001 Prizm? Also, will it be easy to replace. Thanks!
Mar 22, 2012 at 11:33 AM
RIVERMIKERAT
  • 6,106 POSTS
See if it's throwing any codes. Have it scanned for both soft and hard codes. You need to tell them you need both, otherwise they'll only check for hard codes mainly by looking at the Check Engine Light on the dash. If it isn't on, they'll say no codes present. Soft codes won't set the CEL.
Our reference shows the pressure regulator on the fuel rail.
Mar 25, 2012 at 1:18 AM
