2001 Chevy Prizm Engine oil leak?
75,000 MILES • 4 CYL • 2WD • AUTOMATIC
HENRY2001
I changed oil 40 days ago, when I changed the oil, the oil level is in the middle of higher and lower mark. After 40 days, I drove about 2000 miles, and the oil level is still above lower mark, but close to the lower mark.
I didn't see any leak when I park the car, and there is no blue smoke when start the car.
Does my car leak oil or burn the oil?
Thanks,
Jan 28, 2010 at 12:43 PM
  • 31,937 POSTS
Hi there.
If there is no external leaks you will be burning small amounts of oil over a long time, you may not see any smoke but just notice a loss of oil in the sump, the type and grade of oil can also be a consideration in this problem.
Mark (mhpautos)
Jan 28, 2010 at 1:37 PM
HENRY2001
Thanks, There is no leak, how to fix the burnning problem?
Feb 18, 2010 at 10:48 AM
  • 31,937 POSTS
we have to determine where the leak is, it can be via valve stem seals, you will normally see a small puff of blue smoke on cold stat up, do you have this?
Mark (mhpautos)
Feb 18, 2010 at 4:51 PM
HENRY2001
I didn't see blue smoke.
A auto repair checked my car, they said no leak, but don't know if it burns oil.
Thanks.
Feb 19, 2010 at 4:44 AM
