2000 Chevy Prizm Not cooling properly
85,000 MILES • 6 CYL • FWD • AUTOMATIC
KAREN345
I took my prizm into a shop for AC Recharging. They stated that they did not find any leaks so they put in more freon. After one week of use, i turned off the AC to put on heat since the temp outside dropped. now it's not cooling down again. what do you think is the problem. Did they miss a leak and if so, should I have to repay for another 2 pounds of freon?
May 30, 2009 at 2:54 AM
DOCFIXIT
  • 18,828 POSTS
Find a shop that specializes in AC repair. Also have dye put in system if no leak is found. The dye will leave a noticable trail of the leak. Have them do a check of evaporator.
May 30, 2009 at 3:09 AM
