2000 Chevy Prizm engine hesitation
2000 CHEVROLET PRIZM
120,000 MILES • 4 CYL • FWD • AUTOMATIC
88KEYS
My 2000 Prizm hesitates on takeoff & sometimes also stalls. I've tried adding fuel injector cleaner to the gastank to no avail. WHat to do?
May 11, 2010 at 10:54 AM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 11, 2010 at 7:35 PM
